Getrag gearbox strip down and re-build
jimbom30cab
Tech 1 freak
Post Thu Mar 07, 2013 8:49 pm
Hi, anyone got any experience or tips with stripping down this old e34 535 box or similar BMW gearbox
Any tips would be most appreciated
thanks
jim
**BANNED**
Post Sat Mar 09, 2013 5:58 pm
The last time I stripped a gearbox was in 1977,I had a Moggie Minor with a 1098cc engine and no reverse gear.The scrappie sold me a 'box out of a 948cc A40,I then discovered that the larger engine had a bigger clutch and bellhousing,so it sort of made sense to me to pull both boxes apart and transfer the innards of one into the other... :mad:
Getrang 'boxes are so tough that it is always cheaper to swap in another s/h box rather than mess about trying to strip and re-build,I would think that a gasket/seal set alone would render the exercise pointless from a cost point of view.
Youth is wasted on the young.
rix313
Post Sat Mar 09, 2013 9:58 pm
What is wrong with it? As with any strip and rebuild, take it apart, lay it all in an order so you remember how it came off and goes back together. Take photo's of everything for reference. Replace anything that's fucked :)
Post Sat Mar 09, 2013 10:37 pm
If it was Rattling Jim, it'l be the "Layshaft".
Well know problem on these boxes, but never a problem, just noisy.
jimbom30cab
Tech 1 freak
Post Sun Mar 10, 2013 7:46 am
thanks guys, i'm just going to clean it up i think and have a good inspection then put it back together. Reading the manual and taking advice from here i think i'll limit the work to that.
