Inlet mainfold?
E30Adam
- Contact:
There's no difference accross the 325i range.
325e's had a different one as did 320's and 323's but all 325i's have the same manifold. I have about 6 here if you need one!
- popupstands
would there be any benefit from changing 325i manifold to 325e and will it fit ok without problems
E30Adam
- Contact:
Why would you want to do that?popupstands wrote:would there be any benefit from changing 325i manifold to 325e and will it fit ok without problems
E30Adam
- Contact:
- popupstands
someone was advertising on ebay that their was power gains fitting a 325e Manifold, I don't know if true or not
E30Adam
- Contact:
Most definately not, the 325e inlet is much more restrictive than the 325i one. It would work the other way round though if you happened to own a 325e and wanted to fit an "i" manifoldpopupstands wrote:someone was advertising on ebay that their was power gains fitting a 325e Manifold, I don't know if true or not
Andy335Touring
- Contact:
Not unless you ported the head to matchE30Adam wrote: It would work the other way round though if you happened to own a 325e and wanted to fit an "i" manifold
E30Adam
- Contact:
Yes you would need to do that to do a proper job.Andy335Touring wrote:Not unless you ported the head to matchE30Adam wrote: It would work the other way round though if you happened to own a 325e and wanted to fit an "i" manifold
It would still give small gains over the eta manifold though.
