head replacement
alan325i
Post Thu Dec 01, 2005 1:09 pm
Well i need to replace my head (on car that is ) as my engine has turned into the most expensive kettle ever.
Now, i have a replacement hea which came off my old car which is perfect condition, do i need to get this skimmed or will it bo ok just to fit it?
cheers
keith52
Post Thu Dec 01, 2005 5:48 pm
Horses for courses really, the cost of skimming and pressure checking the new (sic) head may seem a waste of money now but what cost is piece of mind as i'm sure you know the head is one of the main reasons of engine failures and if ( a big if ) the head wasn't removed correctly the head could have warped . At least you'll have a better idea of what you're putting back .I know what i would do
Project_E30
Post Thu Dec 01, 2005 5:59 pm
Get a straight edge and that will help you judge whether its warped.
Templ8e30
Post Thu Dec 01, 2005 6:06 pm
Cylinder heads only need to be skimmed if they are warped or the mating surface is damaged according to my local engine specialist.
Good idea to have it checked for cracks though.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
