obc code function?
Cloggy Saint
Ok, i'm fed up using my factory immobiliser, and i know i'm going to lose the fob one of these days. In order to use the obc code function do i just need the one connector going to the relay box or should there be 2, as there are 2 connecting points. Does anyone else actually use their code function?
Dan318-is
there are two connections both going to the code box
you need them both to be connectd for the imbiliser to work
i dont use mine!
i dont use mine!
Cloggy Saint
Dan318-is
on mine, i left both in an the engine ran without the keys
i took one out an it was fine but the code function didnt work
so i jus took the frikin thing out lol
Cloggy Saint
Dan318-is
i dnt htink iv yet to see anyone use it
andrew probably does!
agent006
I use mine a fair bit. Gets a bit embarassing when i forget to put the code in and just end up trying to start the car for ages.
Dan318-is
agent006 wrote:I use mine a fair bit. Gets a bit embarassing when i forget to put the code in and just end up trying to start the car for ages.
agent006
did it at sainsburys this evening.
Try and start
realise it's coded, put the code in
try and start, but realise i need to turn the electrics off and on first
try and start again but forget i need to put the code in again after turning it off
turn it off and on, put the code in, start. go home.
Try and start
