As subject header really. Does anyone know what the standard ride height is for a mtech2 325i. Mine is an 1988 model and was factory specced with the mtech suspension.
However now it sits unevenly with unknown mismatched springs on the front. I plan to replace the springs/shocks all round but want to maintain roughly the same height it has at the moment, although I can't find the original numbers to use as a benchmark.
Standard ride height of an mtech2 car
jmc330i
15mm lower than standard non-Mtech IIRC.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Supafly
Thanks James, do you know what the standard ride height is?
Mine is at approx 601mm front n/s and 620mm front o/s (car is LHD) and 580mm rear n/s and 570mm rear o/s.
If I can find out the standard height I can work out the H&R -35mm (which I've ordered) in relation to my car and also decide on if I should or shouldn't get a pair of e90 front hats.
jmc330i
I don't know the standard height, sorry. My Sport was slightly lower than standard when I got it, my touring was standard 4 pot 4x4 spec, so I fitted my Sports suspension to it and I never measured the height at standard height.
If you've got the -35mm kit, that should be 20mm lower than Mtech height, roughly the same as my Sport. The E90 hats are meant to lower the front a little more, so with the -35mm springs you could be looking at -40-45mm at the front. Having said that, a few people have said they didn't notice any difference with the E90 hats fitted.
James
'91 325i Sport
'91 325i Sport
Supafly
Thanks again James. Think I'll fit the h&r kit measure again and then take it from there.
Hope you have a happy new year
