losing clutch pedal??
pipework
Post Sun Dec 16, 2012 12:01 pm
hi, over the last few weeks ive been losing my clutch pedal. only when i hold the clutch down the pedal goes soft and the car starts to edge forward, it also gets hard to get out of gear when doing this. i fitted a new slave cylinder back in feb, could it just need a fluid change??
thanks.
maggspower
Turbo Farmer Tractor Driver
Post Sun Dec 16, 2012 12:03 pm
Sounds like it needs a master cylinder change as well.
pipework
Post Sun Dec 16, 2012 12:08 pm
leaking passed the seals do you think??
maggspower
Post Sun Dec 16, 2012 12:12 pm
pipework wrote:leaking passed the seals do you think??
Yes. A fluid change can help, but you cant fix worn out stuff with it.
Post Sun Dec 16, 2012 2:20 pm
If you read the tech. posts on here regarding clutch hydraulics, you'll see that it's recommended to change both master and slave when one fails.
When your slave cylinder failed, the piston in your master cylinder would have travelled a little further than it has in the last twenty odd years, and this damages already fragile seals on the crud that has built up.
pipework
Post Sun Dec 16, 2012 2:46 pm
thanks for your help guys!!
milescook
Post Fri Mar 01, 2013 10:04 am
Same problem, possibly, car's been off the road for a while back on now. Leaving this morning, seemed remarkably eager to pull off when changing gear! Went to change to second, was very tricky. Got to a roundabout, went to go in to first, no way I could. IU then realised the clutch fely like it had lost all pressure. Managed to get back home (turned off the engine started in first!).
Only thing I've done is topped up the clutch fluid with brake fluid, perhaps it was getting low as a symptom. Is there i definate way to know if I need to change slave and master cylinders? Can't see much on the wiki how to change them, but searches are bringing up top tips.
Cheers!
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Mar 01, 2013 10:11 am
Yeah, changing the clutch cylinders isn't covered in the Wiki - it's not something I can cover because my car's LHD so I don't have any experience of how it works for you guys.
Basically, if your fluid is dropping then you have a leak. If there's fluid in the footwell then it's the master, if it's under the car it's the slave. Doesn't matter either way, since you ought to change them as a pair.
Changing a slave is easy though; undo the hose just like you would on a brake caliper, crack off the two bolts that hold it to the gearbox, and pull it out. Simple as. It's the master that's a pain since you have to do it upside down in the footwell.
Post Fri Mar 01, 2013 10:25 am
Happened to me on the cab, changed the master and slave, all about £60.
milescook
No probs there's A fair amount of help available on searches:
http://www.e30zone.net/modules.php?name ... h+cylinder
http://forums.seloc.org/viewthread.php? ... #pid198418
http://www.e30zone.net/modules.php?name ... ange+slave
Grr I'll collate all these top tips, pass it over to BrianMoore or someone for confirmation, and post it to you
milescook
Post Fri Mar 01, 2013 10:26 am
Rav335uk wrote:Happened to me on the cab, changed the master and slave, all about £60.
Mega :) Like the sound of that.
Grrrmachine
Pass it to me first if you like; once it's in the Wiki people usually PM me the corrections winkeye
**BANNED**
Post Fri Mar 01, 2013 1:18 pm
Grrrmachine wrote:Yeah, changing the clutch cylinders isn't covered in the Wiki - it's not something I can cover because my car's LHD so I don't have any experience of how it works for you guys.
System is the same and works in the same way :mad:
Only difference is that LHD share the fluid holder for both footbrake and clutch.RHD has a seperate clutch fluid holder mounted on the o/s suspension turret.
G-Bear
Post Fri Mar 01, 2013 1:52 pm
milescook wrote:No probs there's A fair amount of help available on searches:
I started a write up for this. I'll try get it finished at the weekend. Unless you've already got it underway?
Grrrmachine
Post Fri Mar 01, 2013 2:41 pm
Nope, not started anything yet - too much to do in another caverns of the Wiki :D
milescook
Post Fri Mar 01, 2013 10:56 pm
added a few more links to help out in my post earlier.
been looking through the car history tonight. the amount of business money earnt by sewell in bishop stortford on this car is astronomical! i think it had a pretty harsh life in its early days. though retirement hasbbeen kind with 5 yearly services and only about 3000 miles in that time! :D
anyway, i noticed the master cylinder was changed 35000 miles ago, and canteen no leaking from there tonight. i guess that's too long ago and still need to replace the master and slave?
milescook
Post Sun Mar 03, 2013 2:57 pm
All sorted.g bear o have some pretty sexy pictures which would help a wild article , grr can i email them to you both?
milescook
Post Sun Mar 03, 2013 2:58 pm
Wiki article even. Sodding phone
Grrrmachine
Post Sun Mar 03, 2013 3:29 pm
PM'd
