injector removal
mark_i
Post Sun Dec 16, 2012 11:26 am
whats the best tool to romove the wire clips that hold the m20 injectors to the electrical block...
fuel rail/injectors are off the inlet manifold, but is not obvious how the injectors unclip
**BANNED**
Post Sun Dec 16, 2012 2:23 pm
It's a spring clip,if possible,work in a clean area so you can capture the little buggers as you ease them out with a small,flat bladed screwdriver.
Youth is wasted on the young.
steve_k
Post Sun Dec 16, 2012 2:43 pm
small flat blade screwdriver on one side hand at the ready on the other side for when it decides to go "fook you pal i'm off" & land somewhere you'll never find it 8O
mark_i
Post Sun Dec 16, 2012 6:48 pm
thanks guys...all done.
Not the easiest job, its like the connectors were designed for fiiting injectors, not removing.
Off to Injector tune for a clean/refurb...
Post Sun Dec 16, 2012 9:28 pm
Put all the spring clips fully back in place before you refit the rail.
**BANNED**
Post Mon Dec 17, 2012 2:05 am
mark_i wrote:
Not the easiest job, its like the connectors were designed for fitting injectors, not removing.
Correct.
The rail just clips back on.
