crank differences?
Cloggy Saint
gooner1
- Out humping Reindeer
2 piece crank.
Cloggy Saint
gooner1
Ah, understood.
Check on Realoem Cloggy.
- **BANNED**
Do not attempt to remove the 22mm bolt on the nose of the crank!
Holding the pulley to the crank are six 13mm bolts with locking tabs,remove those and the pulley will drop off,the crank damper just behind(toothed edge for the CPS to read)is on a taper,a smart tap with a hitting stick will shift it.
With both upper and lower belt covers off as well,you have plenty of room to get the belt off and back on.
Youth is wasted on the young.
