Hi there as some of you may know I prevent ly purchased a e30 with a m52b28 in it. My question is why does it hit the limiter at 5700 revs as this seems to be pretty low. What way will I Beable to change this? Would I need to chip the ecu?
Cheers alan
Rev range
kam-325i
At the Rev limit, Does it........
A, Bounce Regular
B, Stay Stable @ 5700
C, Splutter
A, Bounce Regular
C, Splutter
kam-325i
Has it got a standard ECU fitted ?
Rancid
Does the m52b28 have a "limp home" mode that could be causing that?
Formerly known as Rancido64.
e30less at present, working on that one....
-> Xbox360 Halo freak, GT: a wild Rancid
Mobile Phone Technical Support:
Got a problem with your mobile phone?
PM me and I'll do my best to help
kam-325i
Most "limp home" modes limit to around 3000rpm.Rancid wrote:Does the m52b28 have a "limp home" mode that could be causing that?
leeparkes
M52 limp mode is around 5.5K.
ajay
Sounds like your ecu is not reciving a road speed signal, the effect is the exact symptoms you describe. Def worth checking, i forget the exact pin/ cable but im sure some on here could help.
kam-325i
Really ???leeparkes wrote:M52 limp mode is around 5.5K.
alangorst
would the road speed signal be received from the front left hub by any chance? as ive got the front suspension in pieces the now and there is a cable there but it wasnt attached to anything :/ and didnt seem to have any where to plug into
alangorst
yeah its the standard seimens ecu as far as i knowkam-325i wrote:Has it got a standard ECU fitted ?
ajay
Best bet is to get the fault codes read and see what comes up and take it from there.
alangorst
Okay thanks for the help on this lads....does anyone know of anyone one on here based in Scotland that knows a good bit on the m52b28 conversions that I could to look the car over when I have it on road to check all is correct with it?
