M20 timing belts
Cloggy Saint
Post Thu Nov 29, 2012 5:06 pm
I see the realoem lists 2 different numbers for M20 belts, but what's the difference?
Post Thu Nov 29, 2012 8:20 pm
IIRC, rounded teeth and square edged teeth.
Cloggy Saint
Post Sat Dec 01, 2012 11:29 pm
Cheers. Is this an item that's best bought from the dealer or would a motor factor give a good quality copy?
Post Sat Dec 01, 2012 11:32 pm
I once had this at a motor factors, I was suprised to learn there were 2 types, one was longer than the other IIRC
buy one from the dealer not that expensive and if you quote your Vin you should get the correct belt,
Cloggy Saint
Post Sun Dec 02, 2012 12:01 am
Cheers, rough price guide, with tensioner?
Post Sun Dec 02, 2012 7:20 am
Contitech manufacture the belts for BMW - which are available from ECP.
Post Sun Dec 02, 2012 12:42 pm
The early square tooth belt was only used on E12s and E21s. If you use an E30 vin you should have no problem getting the right parts. Go ECP , same parts at a third of the dealer price.
kam-325i
Post Sun Dec 02, 2012 1:12 pm
im sure i also saw somewhere that one type has one more ”atooth”a than the other,
Andyboy
Alpina Colada
Post Sun Dec 02, 2012 5:54 pm
Square tooth belts were used on early M20 (M60) engines, 2.0 and 2.3 with carb/K Jet. Replaced in late '81 by round tooth belts so no E30 will have a square tooth belt.
Belt and tensioner well over £100 at BMW, Contitech belt kit £45.
HairyScreech
Post Sun Dec 02, 2012 6:29 pm
Andyboy wrote:Square tooth belts were used on early M20 (M60) engines, 2.0 and 2.3 with carb/K Jet. Replaced in late '81 by round tooth belts so no E30 will have a square tooth belt.
:cry: So my e21 turdmeister will be square tooth then, will have to swap to some spare e30 pulleys so I only need to keep one belt on the shelf for both cars.
First i had heard of this as well!
Would that mean the square tooth is only on the older style stamped pulleys?
Andyboy
Alpina Colada
Post Sun Dec 02, 2012 6:40 pm
Fitting later pulleys is a major ballache. The crank pulley doesn't fit so you either machine it down or fit a later front oil seal housing as well.
Top Tip: just use the right belt.
Post Sun Dec 02, 2012 11:41 pm
I have a new boxed early belt for sale. No E21 will ever be allowed on the premises so I will not use it :)
