Bedding in new brakes.....
miniblob
Post Fri Nov 16, 2012 1:02 pm
Not really technical I know, but I'm just wondering how people bed in they're new brakes???
I've got new ebc discs and yellow stuff pads with new 5.1 fluid throughout.
I've read online people saying things varying from use them gently for 100 miles, to stand on them a few times and they'll be fine - so I normally just start a bit gentle on them and then give them normal road use.
Just thought I'd see what people on here do, or recommend, bearing in mind I am planning to use these on a track day or two!!!
Ta!
327 Touring with bass!!!
kam-325i
Post Fri Nov 16, 2012 4:28 pm
New pads with new disks dont take much bedding in, as both face's(disk's and pads) dont have any wear patterns to "bed into".
Post Fri Nov 16, 2012 4:42 pm
I would use them gently at first, to avoid glazing the new pads.
Remember to use white spirit to wipe off the protective coating on the discs prior to using them!
miniblob
Post Tue Nov 20, 2012 8:30 pm
Not heard about wiping them off with white spirit before!!!
Had them fitted by a place round the corner from me in the end and have been braking gently for a couple of days!!! They already seem a lot better than what came off!!!!!!
Ta!
Gert_8
Post Wed Nov 21, 2012 9:59 am
Braking is for gays...! :D
miniblob
Post Wed Nov 21, 2012 11:24 am
Ha ha, normally just required when some numpty strolls out in front of me!!! Don't wanna ruin the paint!!
Demlotcrew
Post Wed Nov 21, 2012 5:46 pm
White spirit is mineral based, it leaves an oil residue. Best to use brake cleaner or acetone.
You need to contact the pad manufacturer for exact bed in procedures. Everyone is different.
