Hi Guys
This is going to sound silly, but a while back I fitted a rear load cover from a 325i Touring to my 316 Touring which had lost it's basic load cover. The replacement is the one with the integral net which fixes to the roof so it's quite a bit bigger but i used all correct fittings which came with it to fit it.
It dropped in place with a bit of wiggling but I've never been able to remove it! There's no way of releasing the 'blades' which fall into place and it's stuck fast.
Has anyone had a similar issue? Or can anyone advise what i'm missing because I'm sure it was designed to lift in and out like they do in the e36 / e34 / e39 models etc
Thanks!
Ben
Removing rear load cover - help
Sanchez
Grab it with both hands and push the top to the front of the car then lift it out.
eko
- Old timer
Grab it with both hands and twist the top down(towards the tailgate) and lift out.
Sanchez
Just checked, i was wrong. Opps, not good guidance there!!!
G-Bear
I've got the same problem.. Have never been able to get the bugger out, I tried twisting all ways whilst pushing down, it feels like it almost comes out but then pops back into its housed position..
