Lowering and camber advice please
PaddyEnglish
Post Sun Sep 30, 2012 3:01 pm
Hi everyone
I am about to fit a new set of 17s on my car, but I was thinking I should lower the suspension a little before I do as i think it wont look right as it is. My concern is that apparently the rear wheels cannot be adjusted. So this means I will have more positive camber as a result of lowering the suspension which is fine if i wanted to make it a racer but this is a street car that I use everyday for work.
Is there any possibility of adjusting the rear wheels?
verde
Post Sun Sep 30, 2012 3:09 pm
Negative camber not positive, if your puting 17s on you wont be able to lower it much so you wont notice too much camber. Its just a natural thing with e30s that the lower they go the back will camber a bit, you can buy adjustment plates but theyr about 400 bucks
Raise hell praise Dale.
Post Sun Sep 30, 2012 3:41 pm
PaddyEnglish
Post Sun Sep 30, 2012 10:03 pm
Negative, sorry. Thanks for your advice.
DanThe. That kit sounds great, however I don't have the time and the resources to do such a thing. It's something I will do in the future.
Is there something else I could easily do myself. I am only lowering the car a little, just enough so that the gap between the wheel and arch is equal all the way round.
kangman
Post Sun Sep 30, 2012 10:24 pm
hello mate, Im running 17s with a 60mm drop all round.
there is definitely visible camber at the rear. If your looking for a smart drop i would go for a 60front and 40rear drop as it will leave an even arch gap all round.
PaddyEnglish
Post Thu Oct 04, 2012 9:30 pm
Thanks for that.
Do you wrecking springs on eBay are any good. What do you think about eBay parts in general?
PaddyEnglish
Post Fri Oct 05, 2012 1:51 am
Sorry, I meant reckon!
Jim320i
E30 Zone News / COTM Team
Post Fri Oct 05, 2012 7:49 am
Buy a good brand spring set up. Second hand ones can be picked up for great prices. eBay budget is exactly that... Budget.
