Removing ignition lock barrel
greg124
Post Fri Sep 21, 2012 8:40 am
Had a look in the Wiki, and removing the ignition switch from the lock barrel is explained, but how do you remove the lock barrel from the steering column?
Schadenfreude - the German's haven't got a word for that.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Sep 21, 2012 8:49 am
greg124
Post Fri Sep 21, 2012 9:28 am
Precisely.
Thank you very much for pointing me in the right direction.
Grrrmachine
Post Fri Sep 21, 2012 9:53 am
No problem. Just be patient; took me nearly an hour of wiggling with a piece of wire before I got mine out.
greg124
Post Fri Sep 21, 2012 12:40 pm
On mine the release pin is in the side of the barrel, not the end as shown in the wiki.
I acquired some dentists intruments a few years ago, one of which was perfect for this job. Just pushed it in the hole and the lock popped straight out first attempt.
(Dental work done at cut price rates. Anaesthetic extra!)
