PN needed
AlpineCab
Post Mon Sep 17, 2012 9:22 am
Anyone know the Part Number for the throttle body rubber inlet boot for the M20B25 engine (later version for the T shaped idle control valve)?
Jozi
Post Mon Sep 17, 2012 1:04 pm
You should learn to use realoem or bmwfans, all part no's are there :thumb:
Is this what your looking for? http://bmwfans.info/parts/catalog/E30/2 ... ow_sensor/
Post Mon Sep 17, 2012 1:31 pm
Note that you can't determine if it's the hose you require by looking at the illustration. There's a good chance that the same picture is used for the 'L' boot, the 'T' boot and the version that doesn't have a second stub for the brake servo.
AlpineCab
Post Sat Sep 22, 2012 9:51 am
Brianmoooore wrote:Note that you can't determine if it's the hose you require by looking at the illustration. There's a good chance that the same picture is used for the 'L' boot, the 'T' boot and the version that doesn't have a second stub for the brake servo.
Exactly the point Brianmoooore - hence on this occassion realoem is not as useful as it usually is...
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Sep 22, 2012 11:53 am
A good way to check is to find the p/n on RealOEM and then stick that into Google Images. That'll show you whether the boot has the correct elbow or not.
