Clutch Slave cylinder removal issues
Post Mon Sep 03, 2012 8:41 pm
Spend today fitting a new sump and clutch master cylinder to the 325i however when i went to fit the slave i couldnt get the nut of and to cut a story short rounded it off :x would leave it on but thats the fooked bit not the master
i have two options i'am thinking to get the car finished tomorrow.
1. grind the old clutch slave cylinder off around the nut and but the pipe onto the other one, should tighten up fine.
2. cut the rubber pipe and with a jubilee clip put a new screw thread end on (as i have the pipe for the master cylinder in my garage from manual conversion which i can use) - will this work fine ???
Any suggestions
Post Mon Sep 03, 2012 10:07 pm
How about a new flexi pipe :)
Post Mon Sep 03, 2012 10:10 pm
Are you on about the nut that the feed pipe bolts onto the slave or one of the 2 bolts that hold the slave to the gearbox?
maxfield
Post Mon Sep 03, 2012 10:16 pm
FinalD
Post Mon Sep 03, 2012 11:40 pm
I have use of a full set of these...I love them so much. :D
Post Tue Sep 04, 2012 11:06 am
E30BeemerLad wrote:Are you on about the nut that the feed pipe bolts onto the slave or one of the 2 bolts that hold the slave to the gearbox?
the nut on the pipe, going to grind the slave off round the nut and see where i get :? :mad:
