Hi guys n girls.
Well this weekend with any luck I'm going to install my Sony Head Unit and 10 disc changer. It's also got a remote that can be fitted in the steering wheel column.
What I'd like to know is,
1. What are the colours of the wires so I can match them up to the instructions that come with the HU (I've got the ISO connector that fits the HU but not to the loom)...it's a '90 320i E30.
2. Fitting the remote. I'm hopefully going to be able to put some self tappers into the steering column (obviously checking for wiring and steering play)...any useful tips?? Does the shroud just come off easily?
3. Fitting the changer. I seem to get a lot of dampness in the boot, so I fancy putting it in the glovebox. Is the glovebox easy enough to take out (for the wiring) and put back without it going "saggy" like some other BMW's? (especially E36)
Many thanks,
Al
Radio wiring colours
Dom
1. Whack a cheque in the post first class today for Ԛ£6 and I'll get a loom posted up to you tomorrow to arrive Saturdayundergroundstyling wrote:Hi guys n girls.
Many thanks,
Al
2. No comment, not done it!
3. Glovebox comes out stupidly easily, just unclip the hanger things inside it and it drops! Failing that under the passenger seat should suffice.
Beemer325
[/quote]
3. Glovebox comes out stupidly easily, just unclip the hanger things inside it and it drops! Failing that under the passenger seat should suffice.[/quote]
Hi Dom
I have a Pioneer front loader that I'm due to fit to my '90 325i. Would the same loom suffice or would I have to get a different one?
Hi Dom
Guest
1. sorry m8. I'm being thick. The loom is already there...I just don't know what colour is live/speaker/remote etc on the BMW loom.Dom wrote:
3. Cheers dude
billgatese30
have a look in the tech articles at the ice section. read that and its in there somewhere
Dom
Basically I've got drawers full of the autoleads leads to convert manufacturer radio plugs to ISO. My flatmate is an in-car electrician type dude with his own business to seems to have loads left over.
Supplied with most headunits you'll have a lead to plug into the ISO one and the back of the head unit. Other headunits are just ISO connections anyway so don't need this.
For example
BMW ---> ISO ----> Headunit
It's the BMW ----> ISO leads I have. If an ISO ----> Headunit lead is needed it will come with the unit.
Does that explain things?
For example
Guest
Thanks to everyone who replied.
Found this in the tech article!
permanent live - grey/red
switched live - violet
earth - brown
Right Front (+) Grey/White
Right Front (-) Grey/Brown
Left Front (+) Grey/Red
Left Front (-) Grey/Violet
Right Rear (+) Black/White
Right Rear (-) Black/Brown
Left Rear (+) Black/Red
Left Rear (-) Black/Violet
Exactly what I was after.
earth - brown
