Post
Sat Nov 19, 2005 6:12 pm
As far as I know-the 525e diff will probably be a "big case" diff with ratio of either 2.97 or 3.05 ish..
Your IS is fitted with a 4.10 (small case) diff as standard, so if changed to a big case you'd need to shorten the propshaft (not a difficult job!)
The big case weighs more, but is more reliable.
however, either a 2.97 or 3.05 will probably be too long for you to use in your IS.
Basically, Accelleration will be reduced (as 525e diff is "longer") but top speed will be higher.
Your m42 high revving 16v probably wont like that diff at all.
hope this helps
Neil P
