Hi all
I am new to the site so please forgive any errors in the way I submit my post.
I am looking for a wiring diagram for my 316 it has the pierburg 2be carb fitted, the problem is I have no power to any of the control solonoids resulting in hard starting & high idle speed
many thanks
E30 316 engine control wiring diagram
The ECU is under the dash on the drivers side. Not a problem I have ever come across to be honest. Most of the dramas happen when they power up !
snaponman
Hi thanks for the reply, the info I am looking for is where the power supplies come from the ecu to the carb mounted controls, like choke and the idle control
Billwill
Try Google "BMW E30 316 carburetor"
There are a fair amount of hits for common problems, idle problems etc.
TPS
That link brings back a lot of vague memories from near on twenty years ago, when I had one of these with the usual problems. I spent ages tracing the wiring and working out exactly how it was all supposed to work, and did get it all woring for short periods.
IIRC, I ended up fitting some sort of throttle stop to cure the stalling.
My ordeal with the thing ended when someone let me drive a 325 touring they had for sale. Couldn't go back to a 316 after that, so it was sold at a considerable profit to someone who fitted a Weber kit to it.
