my M30 conversion I'm running a E28 535I rad and a large push fan...
if I put a thermastat in my car it runs too hot! and temp keeps on slowly rising!
any ideas? thanks.
m30b35 E30...
Rav335uk wrote:You need an 80 degrees stat for the m30.
A few small holes drilled in the outer circumference of the thermostat is a worthwhile mod.
Running these engines without a thermostat WILL cause damage. The thermostat acts as a restriction in the coolant flow, with it removed the coolant finds the easiest , IE shortest, path around the engine and this results in the rear of the engine running a lot hotter than the front
staley_turbo
Well I didnt know that, Time to put mine back in.pacerpete wrote:Rav335uk wrote:You need an 80 degrees stat for the m30.
Just one hole is needed. About 2mm diameter and at the top. It just helps bleeding air out.
A lot of owners of K Series donks do this - it prevents a thermal shock when the stat opens and dumps cold water into a hot head. Apparently.
