Help with gearbox conversion for m20
kipsy
Post Wed May 16, 2012 9:19 am
Hello, I'm mid way through fitting a 318is e36 box to my m20 325. Before I offered them up I noticed that the input shafts are different sizes. There appears to be a sleeve in the end of the crank that is currently 12mm where the new box needs 15mm. Anyone got any ideas? Ta
E36 input shaft
e30-EVN
Post Wed May 16, 2012 12:26 pm
yes, go to bmw and purchase a 15mm spigot bearing for the new box. prob cost you around the 12 quid mark...
use a bearing puller to remove the m20 spigott from the crank and fit the 15mm e36 item. job done :cool:
kipsy
Post Wed May 16, 2012 12:42 pm
Fantastic. Thanks very much
e21Jason
Post Wed May 16, 2012 12:51 pm
How you sorting the difference in mounting angle for the gear lever
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
kipsy
Post Wed May 16, 2012 1:46 pm
Not yet will cross that road when I get there. I got two linkages to make one out of the two and access to a tig in work
Post Wed May 16, 2012 3:06 pm
Why are you fitting an M42 box to an M20? :?
kipsy
Post Wed May 16, 2012 4:51 pm
Because it's a direct 5th gear and so the ratios will be closer together. 1st will be pretty useless But better everywhere else. 103 moh at 6500 rpm
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed May 16, 2012 4:54 pm
So you just want outright acceleration rather than any sort of top speed?
You could have saved yourself a lot of time and trouble by just fitting the gearbox off a normal 320.
kipsy
Post Wed May 16, 2012 5:24 pm
That's what I'm replacing now- overdrive 5th on that one-125mph top speed
mrLEE30
Post Wed May 16, 2012 6:35 pm
Or saved a load more time a money and fit a 4.5 diff.
kipsy
Post Wed May 16, 2012 8:58 pm
4.45 diff already fitted fella
kevo
Post Wed May 16, 2012 9:38 pm
touche ha ha
mrLEE30
Post Thu May 17, 2012 9:30 am
Ok fit smaller wheels!!!
If you dont mind, what the hell do you plan on doing with it? Hill climbs?
e21Jason
Post Thu May 17, 2012 9:37 am
When I got my m3 it had a 4.45 lsd rebuilt to with extra clutch plates and dogleg box it was pretty quick of the mark and used 4/5 mostly aroudn the track and 2n ran by the end of the pit lane, but it was a gravel spec rally car.
Z3M Coupe for sale
69 Alfa spyder
kipsy
Post Thu May 17, 2012 12:28 pm
I've been running 14s and 15s, will be only using 15s once used up my 14inch Tyres. The car is used for rallying. It will do 103 on 15 inch Tyres at 6500 in 5th once box changed. When I put my m52 28 in I'll hopefully find a 4.1 so will do 112 ish then which is fine. All about acceleration
This is the basic stuff I'll be doing. Great fun
Andyboy
Alpina Colada
Post Thu May 17, 2012 5:43 pm
Not sure the Getrag 250 will last long - really, you need a 310 328i type box.
kipsy
Post Thu May 17, 2012 7:42 pm
I heard the 318is e36 box was the best cheap option. I know someone who runs an m3 motor through one in a compact bm unless I've made a mistake?
kipsy
Post Fri May 18, 2012 11:24 pm
Spigot bearing now changed. Guessed the clutch alignment with some ally bar but will have to make a better version as box awkward to get in. I've now got to enlarge the 10mm holes in the rubber propshaft damper to 12 mm as e36 uses larger bolts. Turning into a bit more work than expected
