Heated Washer Jets
willf
Post Sat May 12, 2012 10:52 am
Hi, could anyone with heated jets please take a picture of where the loom plugs in under the bonnet at all please?
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat May 12, 2012 11:27 am
willf
Post Sat May 12, 2012 12:59 pm
cheers mate, have had a look at that but its for the e36 isnt it?
Grrrmachine
Post Sat May 12, 2012 1:09 pm
Parts list mentions E36, E34 and E30, so the concept is the same for all.
Either way, the wiring definitely comes down on the driver's side of the bonnet, and I'd expect the plug to be down by the washer bottle somewhere considering the amount of wiring in that area.
willf
Post Sat May 12, 2012 1:34 pm
ok nice one cheers!
Post Sat May 12, 2012 9:56 pm
Heated washer jet loom connects to the plug that connects to the existing washer pump.
Disconnect the plug from the pump, plug it into the socket on the jets loom, then push an identical plug to the one you removed from the pump, which is part of the jets loom, back into the empty connector on the pump.
