Has anybody encountered this before? if so how did you get the half a key out of the barrel?
Broken key in lock barrel.
yung-gun
yung-gun
alan1272
sunnyr83
Happened to a me couple years ago during winter due to having a poor quality key copy.
I just left it in there and locked from passenger door.
Most probably need to pop the barrel out and open it out. Pop the door card off and prize off the C shape clip with a long screwdriver through a little hole to release it.
Or you could try and put a flat head in there and turn it while pulling the handle up.
Picking it out with lock picking tools, I tried this and could see the snapped end but just couldn't pull it out enough.
sunnyr83
Here you go mate, plenty of 'how to' on my post....
yung-gun
Yeah guys it's all the way in like. keys snapped off about 2.5 cm snapped inside the door lock and 1 cm left on the key. the lock is out of the door disassembled and in front of me. I've got small angle nosed tweezers gripping it but just cant seem to get it all of the way out :/ I'll grab some photies now mate and upload them
yung-gun
- **BANNED**
I would go to BMW and buy a lock repair kit.
This comes in a bag with all the bits you need to build up a new barrel,costs about £20.
Then if that's your only key that's in that lock,slice the lock barrel at right angles to the key blade to extract the remains,given reasonable luck a key cutter can copy the blade.
In the unlikely event of your E30 still having the original lock/key,your local stealer can supply a new key against your VIN number.
Youth is wasted on the young.
yung-gun
sunnyr83
The worlds strongest magnet??
yung-gun
