is there a cure for a whistling heater fan?
stevo
Post Sat Nov 12, 2005 12:24 am
it only does it sometimes, but its getting more common, and when it does it's bloody annoying!!
it goes "wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!"
anyone got a solution?
cheers
Demlotcrew
Post Sat Nov 12, 2005 7:24 am
nope!
New fan
Andrew
stevo
Post Sat Nov 12, 2005 8:01 am
:cry:
cheers anyway :wink:
Post Sat Nov 12, 2005 12:31 pm
It's the fan motor bearings.
Take the big metal plate off the bulkhead behind the engine, unclip the covers of the fan housings and with something with a long spout put a couple of drops of light oil on the bearings. Run the fan a bit and push the whole motor shaft sideways each way to work the oil into the bearings. Do this two or three times and that should shut them up for the next fifeteen years or so.
stevo
Post Sat Nov 12, 2005 3:04 pm
Brianmoooore wrote:It's the fan motor bearings.
cool! :D
you truly are an electronical genius!
Demlotcrew
Post Sat Nov 12, 2005 6:00 pm
I was under the impression that the barings are nylon and not metal?
Andrew
