Braided hose lines
rizla2
Fri Apr 20, 2012 11:59 pm
Hi Guys,
I was just wondering whether anyone's ever fitted braided hoses and which ones did you fit.
I've looked on the bay and don't really know if it's worth it, also, do I go for the 4 or 6line system?
Ideas and advice greatly appreciated.
Steve.
rich318i
Sat Apr 21, 2012 12:01 am
6 line only should be about £80
Sat Apr 21, 2012 6:29 am
Goodridge. you need the 6 line kit if you have ABS
The ones to go for are the ones with Stainless fittings - the cheaper ones have zinc plated fittings which tarnish very quickly.
redcar
Sat Apr 21, 2012 10:42 am
6 line if car has brake discs on the rear.
If it has drums then only need the 4 line.
Sat Apr 21, 2012 1:53 pm
redcar wrote:6 line if car has brake discs on the rear.
This! 4 line and 6 line has nothing to do whether or not ABS is fitted, other than one with ABS will always need 6 line, as it will have rear discs.
Note that the braid must have another covering on the outside to be road legal.
Jozi
Sat Apr 21, 2012 1:58 pm
I went with stainless end for mine through a group buy. You could try start another group buy and try get some discount?
