Idle
AndyMack
Is the idle speed just controlled by the throttle cable position?
kam-325i
No. What engine do you have ?
kam-325i
Same as mine.....
The idle speed is controlled by the ECU via the ICV (Idle Control Valve) the TPS( Throttle position sensor) and the crank sensor/Induction pick up lead on spark lead No. 1.
