pin 20 question
e30-EVN
Post Sun Apr 01, 2012 1:17 pm
Changing a 318 m40 to 325, I've checked pin 20 and its a red-yellow wire...... So am I right in thinking I can plug the m20 loom in without fire??
As this, on some cars is an earth to behind the glovebox.
T I A
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Apr 01, 2012 1:20 pm
Post Sun Apr 01, 2012 2:09 pm
As long as there is no earth on the car side you should be fine. You only need power there if the car has ABS
Post Sun Apr 01, 2012 2:28 pm
If the red/yellow is on the body side, then you need to arrange a red/yellow to pin 20 on the engine loom as well, if it's not already there.
If the red/yellow is on the engine loom side, check pin 20 on the body side for a brown earth wire.
e30-EVN
Post Sun Apr 01, 2012 2:36 pm
Just checked the doner engine loom, yellow-red is present in pin 20.
Red-yellow is also present car side pin 20
But car is NOT abs equiped.........
