e30 rummble at speed
acidman
Post Fri Mar 30, 2012 1:30 pm
can anyone advise plz when i get to between 35 to 40 mph im getting a rumble from the car that all bearings are fine its not the engine
its quite a deep rumble could it be the prop ?
Post Fri Mar 30, 2012 1:51 pm
Could be prop or diff.
Presumably you've tried pressing in the clutch and just coasting along at the speed that the rumble occurs?
Try draining the diff oil and refill with new stuff.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Mar 30, 2012 3:29 pm
Could even been the handbrake - I've had that one in the past.
Jos
Post Fri Mar 30, 2012 3:46 pm
no Wiki page for that Grr? :mad:
'94 e36 tree climber
mcbonio
Are your wheels balanced?
acidman
Post Fri Mar 30, 2012 9:23 pm
wheels balanced new tyres its auto so cant coast it but when i drop below 35mph rumble stops its actualy vibrating through the car the cars been stood 6 years in a dry barn and put back to mot condition and just passed with minor advise ill change the diff oil tomoz and check the handbrake front to back it may be just grabbing on the drum im thinking inline with you speedtouch could be prop as i dont seem to be able to pinpoint it to left or right
Post Fri Mar 30, 2012 9:53 pm
Try tightening the prop to diff flange bolts. I had the ones on my Minor work loose, and just happened to discover them on a chance checkover. I replaced the standard nuts with Nylocs to be on the safe side.
I heard of a guy on RetroRides with a big Merc coupe who had the prop fall off at high speed! :eek:
