Gearbox and diff capacity
jim_utf
Fri Mar 23, 2012 9:05 pm
Hi guys, does anyone know how much oil I will need to fill a gearbox and LSD on my sport?
Fri Mar 23, 2012 9:35 pm
1.25 litres and 1.7 litres respectively.
Grrrmachine
E30 Zone Wiki / Team Member
Fri Mar 23, 2012 10:46 pm
If you put "Oil" into the Wiki you get the answer immediately
b12rlw
Sat Mar 24, 2012 6:27 am
he's got the answer though.......
jim_utf
Sat Mar 24, 2012 5:03 pm
Thanks guys
Sat Mar 24, 2012 5:51 pm
Make sure you undo the Fill bolt first, if you undo the drain plug first, you might get stuch if the fill one doesn't budge.
Sat Mar 24, 2012 6:15 pm
Rav335uk wrote:Make sure you undo the Fill bolt first, if you undo the drain plug first, you might get stuch if the fill one doesn't budge.
just turn the car upside down ?
Sat Mar 24, 2012 8:14 pm
:? :mad:
