all,
I am abou tto pass some rca cable from the head uni to the rear when I found a white connector not connected under the gear surround, as shown in the picture, can some help, what is it used for?
thanks
Manni
No, its much more worthwhile to get out of the car or climb over the seats to wind the windows downmanni7rehal wrote:Thanks Toby, I am just thinking is it really worth having the rear eletric windows?
All E30s with a sensible number of doors have the rear window loom fitted at least as far as a socket inside the B pillars, where the loom for each rear door plugs in. All rear door looms have the central locking wiring, but only some have the wiring for the windows as well.manni7rehal wrote:Hi
ALl, Thanks, I will check if the looms are in the doors, they would need to be connected to the connectors near the gear stick housing. so the motor will connect onto the current mechanism? and that just leaves the swicthes.
Please can you guys confirm this.. many thanks
Manni
