Help identifying an E30 part
SteMarsden
Post Wed Mar 07, 2012 8:48 am
Apologies for the lack of picture but..... I'm having a go at the wiring on my track car and stripping out anything unneccessary.
There is a relay at the bottom of the off side A-post and im not sure what it is.
Its stamped BMW and on a proper support bracket, I have looked on realoem under 61 25 relays sensors and modules but cant ID it.
Can anyone help?
TIA
Ste.
BMW E30 318i ex PBMWC track car
2011 VW Passat Est
Post Wed Mar 07, 2012 8:59 am
If it's a five pin relay, it's the one that allows you to work the roof/windows with the ignition off, if you open a front door.
Post Wed Mar 07, 2012 9:09 am
Off side it will be the courtesy light timer relay which is usually attached to the central locking module plate.
You can separate the whole central locking/elec windows loom from the main loom very easily 8)
SteMarsden
Post Wed Mar 07, 2012 9:11 am
Brian,
I seem to remember that there were about 10 connections on the top of it, and it was mounted on a oblique shaped passivated bracket.
(I think) it sits in the void under the front speaker hole under the A post
Cheers,
Ste.
2011 VW Passat Est
Post Wed Mar 07, 2012 10:35 am
Ignore my post - I missed the offside bit. Window/roof relay is nearside.
Offside is as DanThe says - Locking ECU, and possibly interior light delay module.
SteMarsden
Post Wed Mar 07, 2012 12:37 pm
Thx DanThe and Brian...
2011 VW Passat Est
SteMarsden
Post Wed Mar 07, 2012 12:47 pm
2011 VW Passat Est
