Unidentified cable dangling...
DanTheDoc
Post Tue Mar 06, 2012 11:59 am
Hi all,
I have a cable dangling near the AFM, it comes out of the same conduit bit as that for the AFM plug. It is a two pin plug that is just freely swinging in the fan wind.
Any ideas what it's for?
bigwinn
Post Tue Mar 06, 2012 12:04 pm
is it an M40 engine?
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Jos
Post Tue Mar 06, 2012 12:09 pm
if it's an M40 engine it for the purge valve as part of the emmisions system, not fitted to UK models.
'94 e36 tree climber
DanTheDoc
Post Tue Mar 06, 2012 12:18 pm
Yeh I should've said really, it's an M40 engine.
Do I not need to worry about this then and leave it dangling?
Jos
Post Tue Mar 06, 2012 12:39 pm
Yuo can tape it to something if you want, but it don't plug in anywhere :)
http://www.realoem.com/bmw/showparts.do ... g=16&fg=10
You are missing parts 15 and 19 and some other bits, don't worry about it
DanTheDoc
Post Tue Mar 06, 2012 1:06 pm
Excellent, thanks for clearing that up!!
Post Tue Mar 06, 2012 2:23 pm
Jos wrote:if it's an M40 engine it for the purge valve as part of the emmisions system, not fitted to UK models.
Same on any E30 engine, 4 or 6 pot, 8, 12 or 16 valves!
You do have hose #20 hanging off of the inlet manifold though (4 pot only} and it's essential this is blocked off.
