Refubed the rear end, but didn't replace the entire front to rear brake line; I put in a join near the fuel filter.
Now it's come to bleeding, and I've got fluid pissing out of the join, so I obviously did something wrong.
I used a male nut on one side, a female nut on the other (both M10x1.0) with double flares on both the old steel and new cunifer pipe. Is that correct, or should I have used different unions or different flares?
Joining Brake Lines
Grrrmachine
- E30 Zone Wiki / Team Member
kam-325i
This is the way I usually do it, but one of the pipesGrrrmachine wrote: I used a male nut on one side, a female nut on the other (both M10x1.0) with double flares on both the old steel and new cunifer pipe. Is that correct, or should I have used different unions or different flares?
needs a double flare.
chh137
I usually put single flare on steel pipe side and double on new pipe (copper or cunifer)
Works every time
Works every time
Grrrmachine
Is single flare where you don't use the flaring die, just the nose of the flaring tool?chh137 wrote:I usually put single flare on steel pipe side and double on new pipe (copper or cunifer)
Works every time
kam-325i
Single flare looks like the end of a trumpet....
just use the pointy end of the flaring tool, no die.
chh137
Single flare is operation 1. Double is operation 1 then operation 2.
In other words....... single flare is convex........double flare is concave. HTH
