Cool Motor???
Wookie
Post Mon Nov 07, 2005 7:24 pm
I have posted this before, but have since then done some research. The motor is a 318i M40, and what happens is this: the temp gauge needle moves up to below the blue mark when you turn on the ignition, but when you start the motor, it moves onto the blue band and does not move from there. I have checked the SI board batteries and are in good nick. I have also had someone test the temp sender unit and said it is functioning fine. Could it be the previous owner has removed the thermostat? Or do you think the gauge is packing up?
tylerma
Post Mon Nov 07, 2005 7:26 pm
have you checked the earthing nut on the back of the guage itself mate
make sure it is tightened up
or if you wait for Brianmoore he has another theory
to try
Wookie
Post Mon Nov 07, 2005 9:24 pm
Yep, checked that as well...
ad318i
Post Wed Feb 21, 2007 4:19 pm
i know this is a v old thread but does anyone know if he found out whats wrong.
i got this on mine.. trying 2 sort it...
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
Wookie
Post Sat Feb 24, 2007 10:24 am
Yep! Got it sorted. Changed the brown temp sensor, all works fine now. Just a bit of a bugger to get in there to change it. Also changed thermostat, cause previous one had been bodged. Temp readings are fine now...
There are two types of drivers: Those who dislike BMW drivers, and those who drive BMWs.
