Anyone recommend a good undersealer, I know Waxoyl is the normally recommended stuff, but has anyone used Dinitrol before, it seems to get much better recommendations on slightly more extreme things needing protection... like seaplanes..
Just wondering what the views might be on this stuff as it redefines NOT CHEAP.
Ta guys
Underbody Sealer
Jos
'94 e36 tree climber
Demlotcrew
I find the Waxoyl stuff to 'wash' off round where the wheels are. But appart form that its held well.Jos wrote:Anyone recommend a good undersealer, I know Waxoyl is the normally recommended stuff, but has anyone used Dinitrol before, it seems to get much better recommendations on slightly more extreme things needing protection... like seaplanes..
Ta guys
Andrew
johnono
TECTYL is good,
and PAVA is a service treatment available too
johnono
Anyone know what the original BMW underseal stuff is?
johnono
all i could find brian, didnt have any larger
Demlotcrew
Thats on back order pending safety issues i have tried to order some
Anyone know what it is in a non-BMW can then?
Andy335Touring
Under body schultz(sp?) Black tar type stuff,most motor factor places do it in a brush on aplication rather than a spray.
johnono
that tectyl stuff is described as a "rubber/resin type substance that dries to a firm, resiliant and tough film"
bullitt
3M!!Brianmoooore wrote:Anyone know what it is in a non-BMW can then?
Jos
Agreed on the Waxoyl washing off, also tends to run a bit on warm days.
Had a look at the tectyl stuff, looks close to the Dinitrol, same buzz words in use
http://www.dinitrol.com/MoreInfo/Car.pdf
Although the Tectyl BT Sealer for marine ballast tanks would probably be better stuff... probably 40gallon drum only though
As you can see from the sig, I am in a perfect position to reseal the underside of the car, there is nothing attached anymore. (On that note you wouldn't belive how light a stripped bodyshell is)
ian332isport
