After a near complete engine rebuilt on my rest E30 320i Cab (M20) i have her up and running for the first time in 3 years (the last owner ran her into the ground and cracked the block).
I have just discovered that the heater blower is knackered, looks easy enough to remove, assuming its proper knackered (everything else on the engine was) can they be restored/overhauled or is it better to replace?
Knackered Heater Blower
aimlessrock
Its probably seized.
You need to undo this spring clip - its a pig as you cant get a proper grip on it and cant really get a screwdriver under it to lever it undone. I put a nail through the small hole on the bottom of the clip and used a pair of grips to undo it.
Stand the motor on end and drip oil into the bearings and spin it until it turns freely.
aimlessrock
many thanks Rob, appreciate the photos...will have a nail on standby!
I will pull it out and have a crack at this.
much apprciated.
much apprciated.
No probs
Rtaylor2208
Easiesr way to get the spring clip off I one of the s shaped screw drivers. The kind for under small things and awkward places. Putting it back on though is still escaping me at the moment
http://www.ebay.co.uk/itm/handy-pack-3p ... 0493261021
Rtaylor2208
Rtaylor2208
