Eccentric Bushes? Which to buy SuperPro / PowerFlex / OEM M3
Also what is the M3 Part Number?
Jibberingloon
MrBenn
rossmc88
I bought some from cotswolds bmw off here in decemeber, cost £46 delivered
Note that this part number gets you two bushes - you only need to order one.
Jibberingloon
The OEM item is more than a Poly Bush......!!
So would you all still go for OEM over Poly?
rossmc88
Every time! Works better and probably lasts longer.
Kos
The powerflex ones have been known to fail due to their shitty 2 peice design
This failure has happened when driving, id always used OEM or treehouse racing ones.
alan1272
HairyScreech
Oem all the way on this one, for twenty quid you get a pair of fit and forget bushes.
