M10 2.0L conversion from carb to L-Jetronic - can't get work
pallermo
Post Wed Jan 11, 2012 1:36 am
Hi guys,
I am so sad that I have to make my first post with my problem. I came on this forum as recommendation from one user at bmwe21 forum. I think also that I can find some help here because my problem is related to BMW E30 L-Jetronic system.
Recently I had an upgrade with my M10 2.0 engine from solex 32/32 to L-Jetronic system. The complete system was taken from E30 87 or 88 (I am not sure but I think that it's 88) Manifold, engine installation, fuel rail, injectors, air mass sensor etc...whole system for this setup. I have upgraded everything and also finished everything with electric but it just want fire up! All indicators on dashboard are working, I have sparks on spark plugs (I have checked). But... - I don't have any fuel - pump is working for 2 sec after I turn the key on contact (I am rechecking fuel pressure tomorrow again ), I have noticed that ECU isn't activating injectors and cold start injectors. I have check all of these injectors and everything is working correctly. I have tried almost everything but it just want fire up. I presume that the problem is with some installation but I think that I have connected everything correctly. Also, I have tried to replace ignition module witch is siemens/Telefunken and still I don't have engine start. The ECU is 0280000328. At the end I thought that the problem is with ECU and maybe with transistor for driving injectors (OM323) but I can't check it because it's Darlington NPN with resistors and diode inside. Tried to google it - to find somebody who did this conversion but I didn't found anything, just found some pictures. Probably the problem is in front of me but I just can't see it. So...at the end the problem is with injectors (fuel) - the ECU isn't opening them and from that reason engine can't start up :(. This L-Jetronic system is with lambda control..
All of these parts for upgrade I got from my friends card, I took it direct from the car except ECU witch was inside of his workshop. ECU was inside in the box with a lot of other ECUs but my friend told me that this is correct one (it was only that one from L-jectronic). Also checked in Bosch ESI and the number give me - E30 316/318i LEjectronic/Motronic from 84-88. In the meanwhile I found from another friend the another ECU which is 0280000330 and Bosch ESI is also giving the same results except it's only giving 318i from 84-88 Lejectronic/Motronic. I tried to fire up with this one but still nothing :) rrrrr (I thought that maybe my friend mistake with it) and I am still at the beginning :) :(((
Also tried to find electrical wiring diagram for this L-jectronic 88' but I can't find it at all. There is everything except this one :) (I have all other manuals Haynes, Bently, BMW but nothing). I have 2 wires witch isn't connected Brown/Yellow 0,75 and White/Green 0,75. I couldn't find out for what kind of purpose these wires are. White/Green is going on pin 22 on ECU and Brown/Yellow on pin 16. I traced this brown/yellow in ECU and it's going on some LM chip witch is some quad differential amplifier and that wire is some input method (pin 4). (I thought that this mayt be some input dependency to fire up - connected this wire to 12V+ with 1K resistor to protect LM but still nothing) I haven't traced this white/green wire... :(
So far - 8 days passed and I still can't get it resolved. If somebody knows something regarding this issue please write here, or maybe if somebody knows for some link with this kind of conversion, please post it here. Thanks a lot!
p.s. I will try tomorrow to measure fuel pressure again, maybe it's not enough to open injectors but I think that I have correct pressure. When I try to fire up I can't hear sound of injectors that they are opening (it's noisy but there is no tak tak tak sound :) ) I am thinking that I can connect analog instrument direct to injector to see if there is some impulse for opening, or I can simply connect some LED with resistor to see if it lights...I don't know... :(
pallermo
Post Wed Jan 11, 2012 1:53 am
Anyway...one very confused and weird situation for me :(
Brian28
Post Wed Jan 11, 2012 6:23 am
Aside from any electronic issues, fuel pumps from a carb system are unlikely to deliver high enough fuel pressure to run the car. Not too sure on the E30, but on other makes of cars that I have converted, it needs to be a low pressure fuel pump if converting to carbs, a high pressure injection pump if converting from carbs. Not sure how relevant your fuel pressure may be to the ECU signals, somebody with more electronic know how should be along soon.
pallermo
Post Wed Jan 11, 2012 3:31 pm
Hi, thanks for reply. I have a proper fuel pump for this system taken from L-Jetronic also so...I just have to check again fuel pressure in the system.
pallermo
Post Wed Jan 11, 2012 3:37 pm
beemerbird
Post Wed Jan 11, 2012 9:26 pm
Pallermo. Welcome to the Zone.
Can you edit your first post with gaps between the sentences a bit? We have many knowledgable people on here, but many will look at your 'wall of words' and move onto the next thread :(
Good luck with your problem.
Beemerbird :D
Ant
Retired Team Member
Retired Team Member
Post Thu Jan 12, 2012 11:31 am
Injectors are trigger by the coil going to ground on these, signal taken via the bulkhead amplification module the to ECU which then calculates engine speed and triggers the inj banks in odd/even as pairs
if you have spark thats half the battle won
the white/green should be a live if memory serves, get a pinout for the ECU and see if there is a missing +12V signal on the pin that matches that colour wire.
an edit of the 1st post defo a good idea, hard work to sift through dude :thumb:
HTH.
