Just checked pin 20 on the c101 plug (fusebox side) and it has a brown wire.... Is this earth? And can I just cut it and extend using 30 amp wire to the earth point??
Many thanks
pin 20 - earth question
e30-EVN
A 2 door e30 with 8 cylinders, what could be better
Grrrmachine
- E30 Zone Wiki / Team Member
What exactly are you trying to do?
Still, a pin-out of the C101 is available here:
http://www.e30zone.net/e30zonewiki/index.php/M5x_Looms
e30-EVN
Its an early car 316 carb, he's putting a 318i (m40) in and we don't want a fire.!
I've inspected pin 20 on his car and it has a brown wire in pin 20........
Grrrmachine
Cut the coont out! As much as possible, put some heat shrink over the end ideally
e30-EVN
Cheers dan, that's the one. So it doesn't have to be lengthened and earthed then?......
And grrrmachine,, that's what I was talkin about, cheers for the link
No the other end of the wire is bolted to the earth point behind the glovebox, which is why you end up with melted loom if the new engine loom has a positive wire to Pin 20
e30-EVN
Ok mate, will do that then.
Cheers as ever mr the
