m42 end float,how much????
jonesy318
Hi guys, just been reading a few things on here and while i'm having gearbox issues and before i put the engine and box back in i'm going to check my m42 for and float movement. question is how much is normal or acceptable and what should i be worried at, anyone know the exact specs or measurements??? want to avoid putting it all in and then find its buggered
cheers Ian
0.08-0.163mm is BMW spec.
redcar
what is float movement.
When the M42 pilot takes a dump before cranking up the awesomeness, if it floats (not very heavy therefore minimum weight reduction) there is a tolerance in the overall measurement from one end of the turd to the other which determines the usefulness of said shit = end float.
Im sure demlot can go into the technicalities of this in more depth
