Is it a relatively easy process to convert a 325 auto car into a 318 manual or is there little pit falls i need to know about?
I know i`ll have to change diff,prop,front springs,loom and ecu but not sure about whats involved with the pedal box.
Auto to manual
Grrrmachine
- E30 Zone Wiki / Team Member
This needs cleaning up, but all the info should be there...
http://www.e30zone.net/e30zonewiki/inde ... _To_Manual
bimanut
Thanks.
Looks pretty straight forward,it was the pedal box etc i wasnt sure of.
The actual pedal box is the same. The clutch pedal and longer shaft can be fitted to you existing box, and the brake pedal changed, but most people just change the whole thing.
E30SPORTMAD
Have a complete manual pedal box if need be?
fixedwheelnut
Don't forget the spigot bearing in the end of the crankshaft, Auto's don't have one but the manual will need it.
E30SPORTMAD
Have these bearings brand new here alsofixedwheelnut wrote:Don't forget the spigot bearing in the end of the crankshaft, Auto's don't have one but the manual will need it.
