when i corner left hard enough to put even a light suspension loading on, i get a whining noise.
could this be wheel bearings?
there's no noise while running straight or cornering right...
whining noise while cornering left.
gareth
Andy335Touring
It does sound like a bearing
Try jacking the car up, grip the tyre top and bottom and see if theres any play in it.
koos
Andy_magic
The rear baerings on my E30 are totally shot, they make a right old row but there is no play in them as it passed its MOT a few weeks ago.
mrLEE30
mine were also shot but no play. its also a guess as to what side has gone!
and of course i guessed wrong! mine made a rumble when going left (especially on motorway) so we guessed right bearing....our survey said AHHARR. nil point.
mrlee
mrlee
Cotty
- Hartge Crew
I used to get that, its stopped when I dumped the exgareth wrote: i get a whining noise.
gareth
it's deffo not scrubbing arches (i'm an expert at that!)
can't feel any play but i'll have a better look at the weekend...
ianeire
Do the bearing. I had the same problem in a Saxo. Passed the NCT/ MOT without any problems as they're was no play in the wheel but when I changed the bearing it cured the problem noise.
Whine was occuring while I was driving normally, it was a lot louder when turning to the left and eventually I was getting vibration through the clutch. Damaged it I think when I got a blow out... no other explanation for it that I can think of.
