Rear Hard Brake Lines
tom325sport
Post Mon Dec 26, 2011 8:29 pm
I will be fitting the last of the rear brake lines - I have bought cunnifer and the unions but after seeing some pictures on here, there seems to be a clip that joins the flexi and hard pipes -
Looks like 6 on here...
http://bmwfans.info/parts/catalog/E30/C ... pipe_rear/
What do these clips do and do I need them as they are not on the diagram above?
Post Mon Dec 26, 2011 8:34 pm
number 6 fits between hard lines and flexies to hold/secure them in place on body mounts
tom325sport
Post Mon Dec 26, 2011 8:57 pm
Thanks for the heads up. Will order them tomorrow. Are they dealer only or would ECP do them do you know? Also how many would I need? Thanks
toby
Post Mon Dec 26, 2011 9:00 pm
Tap your chassis number into the parts catalogue in this section and that may help. It's probably a dealer only part but you could check ECP's website.
Post Mon Dec 26, 2011 9:10 pm
Hope you've used 'short' M10 male ends for your pipe, otherwise the clips won't fit.
tom325sport
Post Mon Dec 26, 2011 9:12 pm
Brianmoooore wrote:Hope you've used 'short' M10 male ends for your pipe, otherwise the clips won't fit.
Yes ordered these. Will have a go tomorrow. :)
Post Mon Dec 26, 2011 9:34 pm
Dealer only, or you may be able to re-use your old one's
tom325sport
Post Mon Dec 26, 2011 9:38 pm
Yep thought so. They don't look expensive anyhow. :)
Post Mon Dec 26, 2011 9:47 pm
Always worth replacing - they will have started to corrode, even if they are still passable.
I buy these in bulk, and they weren't expensive the last time I bought a batch, although that was a year or three ago.
Also, by far the easiest way to remove the old stuff, is to chop the hard lines just behind the pipe ends, and then destroy the clip.
Post Tue Dec 27, 2011 7:06 am
They're pennies from BMW - you might even find they're in stock 8O
Jozi
Post Tue Dec 27, 2011 2:54 pm
Wee bit of topic....
Does that mean these: http://www.ebay.ie/itm/ws/eBayISAPI.dll ... SA:IE:1123 won't fit/work?
Post Tue Dec 27, 2011 3:12 pm
Doesn't say in the ad., but if that's a pic. of the actual item, it looks like it is the 'short' version.
I'd like to find a source of 'short' brass ones, but have only managed to find 'long' ones.
Jozi
Post Tue Dec 27, 2011 3:18 pm
They measure about 16-17mm top to bottom, look much like in the picture. If their the right ones I'm glad to find out now rather than realise their not when I get at the brakes.
Post Tue Dec 27, 2011 4:00 pm
'Short' ones are 16.3mm and 'long' ones are 21.5mm, overall length. Just measured some.
Jozi
Post Tue Dec 27, 2011 4:30 pm
Brianmoooore wrote:'Short' ones are 16.3mm and 'long' ones are 21.5mm, overall length. Just measured some.
Thanks for checking, it's short ones I have so :)
tom325sport
Post Mon Jan 02, 2012 4:37 pm
Not done this yet but will start tomorrow.
Quick question - are the flares single or double flares on the hard pipe?
I'll need to practise tonight as I've not done it for a long time!!
Post Mon Jan 02, 2012 5:42 pm
Brianmoooore wrote: I'd like to find a source of 'short' brass ones, but have only managed to find 'long' ones.
Wow, bit over the top Brian? I find greasing them up everywhere before assembling gives them a long life, covered with waxoil afterwards of course.
Ive taken apart joints that are only 12 months old and they have been seized up/rusted because eejits put them together dry :mad:
tom325sport
Post Mon Jan 02, 2012 6:25 pm
OK had a quick practise...
Left is Single Flared Joint
Middle is Double Flared Joint
Right is OLD BM pipe
Mine don't look like this? Any tips?
kam-325i
Post Mon Jan 02, 2012 7:14 pm
Double flare.
what do yours look like ?
and what kit are you using ?
tom325sport
Post Mon Jan 02, 2012 8:00 pm
I suppose they look like the OE ones. The kit is as old as the world but still in very condition. Thanks will do Double flaring!
Post Mon Jan 02, 2012 10:16 pm
Imagine the middle one once its been compressed :wink:
tom325sport
Post Mon Jan 02, 2012 10:32 pm
Do you think it needs compressing a little more?
kam-325i
Post Mon Jan 02, 2012 10:40 pm
tom325sport wrote:Do you think it needs compressing a little more?
NO. The middle one is fine........
Post Mon Jan 02, 2012 11:21 pm
tom325sport wrote: The kit is as old as the world but still in very condition.
I doubt if it's older than mine - I've had it for around forty years, and like yours, it still makes perfect flares, and is easily used in confined spaces.
The middle pipe is absolutely perfect. It'll take up its final shape when it's been used.
tom325sport
Post Mon Jan 02, 2012 11:27 pm
Thanks Brian that's great. Yes I inherited mine through an old neighbour who was an 80 year old mechanic before he
Retired and passed this on to me. It's used but in great condition!! I'm sure it will be used for more years to come. I don't think it's 40 years however.
