1988 E30 No Spark When Hot
OliverM3
Post Sat Dec 24, 2011 9:47 pm
Hello I'm hoping someone can help I'm about to give up.
The Problem is my 1988 325is will start in the morning and run all day long but as soon as I shut it off I can't start it back up for an hour or two.
The motor just cranks and cranks with no spark (used screw driver on block to test) . I can smell fuel and the fuel pump is running.
I’ve replaced the cap rotor, plugs, coil, plug wires and crank position sensor.
I’ve also swapped the DME relay with the fog light relay to test and that did not work.
Also I pulled the DME and it has a date of 2009 on it and looks new. So someone has replaced it. That doesn’t mean that it hasn’t gone bad again but I’m not sure.
The car was sitting for a long time when I purchased it but in great physical shape.
At first I had a high surging idle so I replaced.
Idle control Valve.
All Vacuum Lines
Throttle position sensor.
Brown and Blue Temp Sensors.
Throttle Body Gasket.
MAF Sensor
Also Timing belt and Water pump.
So the Idle is good but I still have a Check engine light (FF 2d)
for a temp sensor which is strange.
Sensor tests good but no voltage at the plug. I'll test at the ECU next.
But I don't think that's causing the no spark when the car is hot.
I don’t know where to go from here except maybe replacing the DME
Thanks for any help. And Merry Christmas :)
Post Sat Dec 24, 2011 10:43 pm
If you're absolutely certain that the fuel pump is running while you are cranking the engine, first check that there is 12 volts on the + terminal of the coil while you are cranking, and then suspect the coil itself.
OliverM3
Post Sun Dec 25, 2011 3:52 pm
Brianmoooore wrote:If you're absolutely certain that the fuel pump is running while you are cranking the engine, first check that there is 12 volts on the + terminal of the coil while you are cranking, and then suspect the coil itself.
I'm not 100% sure that the fuel pump is running. I assumed so since there's a heavy gas smell when it's cranking over for a long time.
I've checked the 12 volt with the ignition on I haven't had a chance to test with a helper cranking the engine but I do get 11.7volts with the ignition on.
New symptom this morning the car isn't starting at all.
and I pulled a plug wire to test for spark and there is no spark.
Still 12 volts at the coil and the coil is brand new.
Hopefully none of the new parts I installed were defective so this new situation is just a progression of the original problem.
There is another thing that's odd with the car. it seems that someone bypassed the safety switch on the clutch pedal.
Because when the car would run you could start it without depressing the clutch.
I think I may look there to see if I can find how that is bypassed.
Post Sun Dec 25, 2011 4:42 pm
You sure you have an E30? There's no starter inhibit switch on the clutch of any E30 I've ever seen.
A duff crank position sensor is a common cause hot restart issues, but in this case the fuel pump doesn't run either.
OliverM3
Post Sun Dec 25, 2011 5:55 pm
Brianmoooore wrote:You sure you have an E30? There's no starter inhibit switch on the clutch of any E30 I've ever seen.
That's good to know this is my first e30.
My last BMW was a e46 m3.
I just assumed that the e30 had a clutch safety.
I'll have to test the new crank position sensor that I put on but I can't see that being bad it's brand new.
mr_dink
Post Sun Dec 25, 2011 6:11 pm
I think maybe the OP is in the US so it could be the clutch switch for cruise control?
Post Sun Dec 25, 2011 6:12 pm
Loads of nanny stuff on an E46 that you won't find on an E30.
OliverM3
Post Sun Dec 25, 2011 10:39 pm
I'm getting old I was going to test for spark again tonight and I'm about to pull a wire off of the distributor to ground it out when I realize that the last time I tested I did the same thing.
So of course I'm not going to get spark from the plug to the end of the wire.
Well I popped off the wire at the plug and sure enough I do have spark.
So I jump pin 80 and 37 on the fuel pump relay and I do hear the fuel pump.
I'm still thinking that my original temp sensor check engine light has something to do with all of this so I trace the harness and at the first twist lock I test the connection.
Everything is good to the temp sensor but not to the dme.
so I cleaned all of the connections at the plug and the car fired right up and the check engine light is finally gone.
[/img]
I guess this connection handles the injectors as well?
I hope this was finally the solution to the problem.
I’ve had it running in the garage for a half hour now and I’m about to go out and shut it down and start it back up to see if it starts hot.
Thanks for all your help.
Post Sun Dec 25, 2011 10:45 pm
It certainly does! There was a BMW TIS issued many years ago, that gave instructions to cut a small hole in the lower rubber boot of that plug and socket, in order enable any water that gets in there to drain off.
P.S: It's not good practice to run or crank a car such as this with an ignition HT lead disconnected from a plug. Without a spark gap to keep it under control, the HT voltage can rise to many tens of thousands of volts, and this can arc from the coil king pin, either externally or internally, to one of the LT posts, which can damage the ECU or other electronics on the car.
OliverM3
Post Sun Dec 25, 2011 11:02 pm
I can't believe it even my temp gauge that use to bounce like mad is stable.
I was about to take apart the dash to correct the jumpy temp gauge.
Post Sun Dec 25, 2011 11:09 pm
Temp. gauge signal runs through this connector as well, although the usual cause of a jumping temp. gauge is a loose brass nut on the back of the instrument cluster.
What have you done or inspected on this connector? The real problems are usually under that lower rubber boot.
OliverM3
Post Mon Dec 26, 2011 12:05 am
Brianmoooore wrote:Temp. gauge signal runs through this connector as well, although the usual cause of a jumping temp. gauge is a loose brass nut on the back of the instrument cluster.
I had read that the brass nut was the cause of the jumping temp gauge. I was going to take care of that when I replaced the broken gears on the odometer that's stuck at 168,000 miles.
I didn't do anything with this connector previously but unplugging and testing between the temp sensor connections.
I took a wire brush and cleaned the green deposits off of both sides of the plug and everything works now.
But I'll have to pop the lower boot off and inspect that tomorrow.
Thanks for the advice.
It has been running for about an hour now and I'm able to shut it off and restart. And there's no check engine light still.
I really can't believe it was that easy.
OliverM3
Post Mon Dec 26, 2011 12:33 am
I think I'm really going to enjoy the e30 now that I'm getting close to sorting out the issues.
I do miss my e46 though.
But with the economy I had to look for cheaper toys and the e30 seemed like the perfect solution.
