hi all, if you read my earlier posts youll know im doing a power steering conversion.
Everything is on and bolted up ect, but now the wheels foul on the track rod ends.
I swapped my manual rack from a 1985 pre 316 for a power rack out of a 1989 316i. Is there any difference in the size of the racks and tie rods ect?
Everything is fitted right and the track rods measured and set so im confused now!
power steering conversion ???
I'm confused as well! The track rod ends are bolted to the steering arms on the hub, which are presumably the same ones as you've always had, so there shouldn't be any changes here at all, unless you've fitted some grossly oversize rod ends.
The racks and tie rods are of similar dimensions, but aren't relevant anyway to what you're describing.
gazwhittle
i know i dont understand either mate. ill get another look after near year and decide whats actually causing it. i just wanted to clear up that all racks , tie+track rods are the same length.
gazwhittle
right just had another look and it the splash guard catching. is there any variation in no ps tie rods and ps tie rods ?
