Proper dumbass question this but i'm getting cheesed off now............
Need to change the center bearing on my prop while it's out of the car but i just can't get the prop to split, do they have a tendancy to seize?
I've got the collar nut undone, it's had WD sprayed down the splines last week in a hope that would soak in a losen it a littlebut it's still not budging!
Tips for splitting a prop
Kedge
Kedge
That's no bother, it's still got the original markings on it.
As far is i understand, you just undo the collar nut and they slide apart but this seems pretty well stuck.
maf260
I may be confusing this prop with one from another car, but have a look to see if there's a circlip buried in there somewhere...
Kedge
There's one that secures the bearing but that shouldn't stop the prop splitting, have undo that already incase though.
gooner1
- Out humping Reindeer
http://www.realoem.com/bmw/showparts.do ... g=26&fg=10
Not sure if this helps mate but can't do any harm.
Kedge
Just kinda confirms it is just seized in place i think Rob, i've had heat on it a couple of times and have now left it stood up with a load of WD in a hope it can soak down the splines. Need a new collar nut now though as i never realised they had plastic inside them
Do you have a well fixed vice? You can put one end in the vice and with a foot on the vice give it a good tugging..
