thanks in advance
LSD bearings/seals
mrb27
anyone know of a source to get a LSD rebuild kit? or will it be a case of getting bearings here.. seals there.. etc
thanks in advance
thanks in advance
steve_k
gareth on used to do it for a fee but i don't know if he's been on in a while.
start a thred in the FAO section/search his username & see if there is the option to email him.
DHFiS
maxfield
BMW still sell the seals and bearings etc
mrb27
ok thanks, didnt want to go direct to bmw as they will rip my arse out on price, the seals i would use oe but the bearings dont have to come from bmw
mrb27
also is there a way to test the lsd lock? ive heard about jacking one wheel off the ground and see if its able to be turned but never tried to test the unit..
leeparkes
You use a torque wrench on a wheel bolt with one wheel in the air, iirc it should be around 80Nm before it slips.mrb27 wrote:also is there a way to test the lsd lock? ive heard about jacking one wheel off the ground and see if its able to be turned but never tried to test the unit..
mrb27
oh, great
ill try it once its built... should prob have tested it before it came off the car
though the diffs been in the boot of my winter car for 8 months anyway
redcar
I think you can get the ramp angles changed for more percentage lock up
Reshimming I think it's called.
mrb27
yh im not sure i want to open the lsd unit, ive done diff before so the service, bearing/seal change is no problem but i dont know what to expect when i open the lsd unit itself..
is there any benifit to opening the unit guys? does it get clogged?
i did read somwhere about going over the plates with sandpaper to rough them up for more grip but that was old pub talk
gareth
Still here and still doing LSD rebuilds
PM me if you want to chat
