Should be refitting the rocker cover tomorrow with the new OEM gasket and D shape bung.
Should I use some gasket sealent? I have cleaned up the cover and the head where they join to get a nice flat surface.
It was leaking a little oil from here before removed so want to get a good tight seal.
Rocker Cover Gasket Sealent Yes or No?
Rtaylor2208
greg124
I have read somewhere on the zone that "real engineers" use only a smear of grease.
Personally, I didn't use anything when fitting a new rocker cover gasket to an M40 engine, and it doesn't leak.
Schadenfreude - the German's haven't got a word for that.
Sanchez
no from me.
Torque it down and check it again after a week or two of driving.
Rtaylor2208
PS. Its a M20 if that makes any difference.
gooner1
- Out humping Reindeer
Was not the grease for the Sump gasketgreg124 wrote:I have read somewhere on the zone that "real engineers" use only a smear of grease.
Though i s'pose if it works there......then again you are more likely
to remove the Rocker cover than your Sump.
Sanchez
Grease the sump gasket to stop it drying out which is when it stop sealing and starts leaking.
Put the cover on without the gasket first, insert a strip of the thinnest paper you can find between the two, and check that it is gripped by the weight of the cover all the way around.
If it passes this test, the gasket can be fitted dry.
Rtaylor2208
Thanks Brian
greg124
thanks for setting me right gooner & Sanchez - half remembered 'facts' can be a dangerous thing
Last one I fitted I used a genuine gasket with a very light smear of grease after cleaning both surfaces first. Didnt leak
