Head drilled? any ideas
TouringTash
Came off a working lump, thoughts please.
318i Touring
It's part of the oil feed arrangements to the top end, IIRC.
TouringTash
Cheers Trevor & Brian, now that I'm looking at it with open eyes and not OMG what's gone on here I can see the extra bit of 'meat' @ 4 O'clock from the drilled point on your lovely, clean and shiny head.
Time for a strip, clean and send it off for some work then.
Thankfully I can't help Hairy with getting to the bottom of why heads crack on 6 pots
http://www.e30zone.net/modules.php?name ... c&t=210764 something you two would know tons more than me about. I would blame a lack of mechanical sympathy for each and every failure and a failed viscous.
318i Touring
fowler
- Boost Junkie
Heat coefficient between to disimilar metals.
me thinks
EX A-Tech Workshop bitch !!!
gone but not forgotten
HairyScreech
im currently wondering if there is something that promotes a hot spot on one side of the head resulting in a hot sides and cold center, thus putting stress into the material in the center.
but that's a discussion for after i have spoken to the unis materials and structures specialist.
as far as that head goes everyone i have seen so far of all types has had that drilling, not sure why they chose to feed the oil like that but not had a good look at it.
TouringTash
fowler wrote:Heat coefficient between to disimilar metals.me thinks
318i Touring
fowler
- Boost Junkie
how does
TouringTash
working late?
Or hiding from the Mrs?
318i Touring
fowler
- Boost Junkie
Nights mate only 4hr45mins to go
TouringTash
lol Glad it's going well.
Had any karzis to sort?
318i Touring
fowler
- Boost Junkie
na not yet mate..
I think it's to "stall" or delay the drain back to the sump. If it direct feed and not off set, the return would be to quick. It may also have to do with crank case pressure.HairyScreech wrote:im currently wondering if there is something that promotes a hot spot on one side of the head resulting in a hot sides and cold center, thus putting stress into the material in the center.
Although they have been know to crack all along under the cam, more often than not, it's at the rear above 6 5 & 4 they go. The reason? M20's run hotter to the rear than the front. And as Si says, 2.7's run even hotter. I can physicaly feel that my 2.7 runs hotter than my old 2.5 when I open the bonnet.
Well, there's six exhaust ports on one side carrying gas at a few hundred degrees, and six inlet ports on the other, flowing air at the ambient, and being refrigerated by vaporising fuel.HairyScreech wrote:im currently wondering if there is something that promotes a hot spot on one side of the head .
e301988325i
Sorry for the hijack, but has anybody suffered a crack head with a tubular manifold fitted? I'm thinking a tubular manifold will hold a lot less heat then the cst logs when the engine is switched off.
I said:
e30topless said:
lock the wife in there
