Can anyone explain rthe best method of removing the injectors? At the moment I have the rocker cover off as the gaskets leaking and it seems that theres more access to the injectors.
Or is it a take of taking the manifold off?
As far as I know they have never been done so thought while the cars off the road anyway should get them done.
Removing Injectors
Rtaylor2208
Black_Potato
which engine ?
3x S14 Rightness....
Rtaylor2208
Sorry, keep forgetting that when posting M20 325 auto.
lamby
unclip the brown/blue sensor plugs/undo plug under manifold,twist type,undo the four nuts,10 m/m.undo fuel feed and fpr feed.undo fpr nuts 2 off(you may not have to undo them but...)then prise up with a screwdriver on the rail gently at one end then the other end etc etc and they pull out towards you over the rocker cover.if you have a 90 onwards you will have to unclip the injector bar that runs all the way along housing the wiring to each injector,then you can see the four bolts better that hold the rail on.no need to remove manifold.easier with rocker cover off.
Rtaylor2208
Thanks lamby, will try and have a bash at this tonight.
